Zum Hauptinhalt wechseln
Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement
Was du brauchst
Einführungsvideo
  1. Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement, Burner Head and Igniter Assembly: Schritt 1, Bild 1 von 2 Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement, Burner Head and Igniter Assembly: Schritt 1, Bild 2 von 2
    • Assess the stove to ensure the burners are in the off position.
    • The off position is marked on the dial. Each knob will have an arrow that points up to indicate the stove is "off".
  2. Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 2, Bild 1 von 1
    • Put on rubber insulated safety gloves.
    • Disconnect the power cord from the socket.
    • It is important to unplug the unit before disassembling the burner to avoid injury.
  3. Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 3, Bild 1 von 1
    • Remove the burner grate from the stove top.
  4. Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 4, Bild 1 von 1
    • Turn the burner in a counterclockwise direction to remove it from the range.
    • Don't yank it off as it is connected to the stove by two wires.
  5. Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 5, Bild 1 von 1
    • Inspect the wiring for any defects.
    • Frayed or exposed wiring can cause the burner to malfunction, leading to an electrical short in the unit.
  6. Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 6, Bild 1 von 2 Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 6, Bild 2 von 2
    • Pull downward on the silver connector to unplug the black wire from the ignitor's white connection point.
  7. Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 7, Bild 1 von 2 Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 7, Bild 2 von 2
    • Pull the yellow wire out by the silver connector from the connection point.
  8. Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 8, Bild 1 von 3 Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 8, Bild 2 von 3 Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 8, Bild 3 von 3
    • Push the black wire onto the new ignitor and the yellow grounding wire onto the connection point on the burner until both are securely connected.
    • Use caution when terminating the black wire onto the igniter. The white insulator is delicate and can break under too much force or if dropped.
  9. Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 9, Bild 1 von 2 Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 9, Bild 2 von 2
    • Replace the burner so it sits flush with the stovetop.
    • Screw it in by hand in a clockwise direction.
  10. Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 10, Bild 1 von 1
    • Plug the power cord back into the wall.
  11. Maytag MGR44552BDW Burner Head and Igniter Assembly Replacement: Schritt 11, Bild 1 von 1
    • Replace the grate and test the new burner to ensure the new burner is functioning properly.
Abschluss
Marcus Gasaway
193 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 54
Insgesamt: 691
