Zum Hauptinhalt wechseln
Maze Speed SSB-508 Power and Volume Button Replacement
Was du brauchst
  1. Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: Schritt 1, Bild 1 von 3 Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: Schritt 1, Bild 2 von 3 Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: Schritt 1, Bild 3 von 3
    • Remove the back cover by gently prying open the bottom left corner of the case with the plastic opening tool.
  2. Maze Speed SSB-508 Power and Volume Button Replacement: Schritt 2, Bild 1 von 2 Maze Speed SSB-508 Power and Volume Button Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • There are three areas holding the power and volume buttons in place. Gently pull the bottom of the power button with a pair of fine-tip tweezers to release the lower half.
  3. Maze Speed SSB-508 Power and Volume Button Replacement: Schritt 3, Bild 1 von 3 Maze Speed SSB-508 Power and Volume Button Replacement: Schritt 3, Bild 2 von 3 Maze Speed SSB-508 Power and Volume Button Replacement: Schritt 3, Bild 3 von 3
    • Carefully remove the top section of the button with the fine-tip tweezers . This should free the button completely.
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 440
