Einleitung
This guide will show you how to replace the power and volume buttons in a Maze Speed SSB-508 phone. If the power or volume buttons are unresponsive or malfunctioning, they may need to be replaced. To complete this guide, a plastic opening tool, tweezers, and a new button piece is required. Precision is recommended, as to not damage any components.
Was du brauchst
Remove the back cover by gently prying open the bottom left corner of the case with the plastic opening tool.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
There are three areas holding the power and volume buttons in place. Gently pull the bottom of the power button with a pair of fine-tip tweezers to release the lower half.
Carefully remove the top section of the button with the fine-tip tweezers . This should free the button completely.
