Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
We will be disassembling the laptop down to the heatsink and CPU, to apply some thermal paste with a higher grade of conductivity.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the battery by sliding both sliders to the left.
    • Remove the battery by sliding both sliders to the left.
    • Hold the left slider as you slide the battery away from you.
  2. Press and hold the power button for 10 - 15 seconds, to release any excess power from the laptop.
    • Press and hold the power button for 10 - 15 seconds, to release any excess power from the laptop.
  3. After removing the battery, undo the single screw holding the RAM compartment lid.
    • After removing the battery, undo the single screw holding the RAM compartment lid.
    • Gently pop out the lid with a few clicks.
  4. Undo the white and black cable, and the screw.
    • Undo the white and black cable, and the screw.
    • Lift the wifi board up and away from you.
  5. Pry the metal clips holding the RAM units outward which will make the uint pop upwards. Slide the unit out, towards you.
    • Pry the metal clips holding the RAM units outward which will make the uint pop upwards.
    • Slide the unit out, towards you.
  6. Undo the single screw holding the hard drive lid.
    • Undo the single screw holding the hard drive lid.
  7. Undo the single screw holding the hard drive.
    • Undo the single screw holding the hard drive.
  8. Use the black tab to slide the hard drive backwards. Pry the hard drive up, on the far side and it slides out.
    • Use the black tab to slide the hard drive backwards.
    • Pry the hard drive up, on the far side and it slides out.
    • Be careful when prying the hard drive out of the case, you might drop it and damage it.
  9. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  10. Push the 4 black tabs located at the top of the keyboard, under the case. Push the 4 black tabs located at the top of the keyboard, under the case.
    • Push the 4 black tabs located at the top of the keyboard, under the case.
  11. Be careful when removing the keyboard from the case, it is still attached at the bottom. Pry the black tab backwards, to remove the cable.
    • Be careful when removing the keyboard from the case, it is still attached at the bottom.
    • Pry the black tab backwards, to remove the cable.
  12. On the bottom of the case there are 2 sliders, use these to release the optical drive. On the bottom of the case there are 2 sliders, use these to release the optical drive.
    • On the bottom of the case there are 2 sliders, use these to release the optical drive.
  13. Undo the 11 screws holding the bottom of the case.
    • Undo the 11 screws holding the bottom of the case.
  14. Remove the 2 cables, revealed by removing the keyboard. The cables mentioning "MB" can only be removed after opening the case. Remove the 2 cables, revealed by removing the keyboard. The cables mentioning "MB" can only be removed after opening the case.
    • Remove the 2 cables, revealed by removing the keyboard. The cables mentioning "MB" can only be removed after opening the case.
  15. Pry open the case using something soft, preferably your hands or a spudger.
    • Pry open the case using something soft, preferably your hands or a spudger.
  16. When the case is completely lose it will still be attached by the "MB" cables. Remove those before completely removing the case.
    • When the case is completely lose it will still be attached by the "MB" cables. Remove those before completely removing the case.
  17. Undo the single screw holding the motherboard.
    • Undo the single screw holding the motherboard.
    • Undo the 4 cables highlighted in blue.
  18. Also remove the black and white wifi cable from under the motherboard.
    • Also remove the black and white wifi cable from under the motherboard.
  19. Lift the motherboard out of its socket. The bottom left may get stuck a bit. Don't force the USB sockets.
    • Lift the motherboard out of its socket. The bottom left may get stuck a bit. Don't force the USB sockets.
  20. On the flipside of the motherboard is the CPU covered by the heatsink. Before removing the heatsink, remove the fan cable looping over the heatsink.
    • On the flipside of the motherboard is the CPU covered by the heatsink.
    • Before removing the heatsink, remove the fan cable looping over the heatsink.
    • Remove the 6 screws, holding the heatsink.
  21. First you will need a card to scrape off the old paste. Keep a coffee filter ready to clean the card.
    • First you will need a card to scrape off the old paste. Keep a coffee filter ready to clean the card.
    • Both the heatsink and CPU's must be totally cleaned of any remaining grease.
    • The triangular part on the heatsink leads to the graphics card.
  22. Be very thorough, any remaining grease may render your new layer of paste useless.
    • Be very thorough, any remaining grease may render your new layer of paste useless.
    • The top cores are the CPU, still not cleaned.
    • The bottom core is the newly cleaned video card CPU.
  23. Use alcohol or a oil-free degreaser and coffee filters or a lint-free cloth. Use alcohol or a oil-free degreaser and coffee filters or a lint-free cloth.
    • Use alcohol or a oil-free degreaser and coffee filters or a lint-free cloth.
    • Apply the paste on the CPU's very carefully, you don't want certain thermal pastes on electrical circuits.
    • Your paste needs to be distributed evenly on the whole metal cap of the CPU.
    • Reverse engineer this guide to put the laptop back together.
    • Let the paste settle in by letting the computer run for a few consecutive hours.
    • Run a temperature monitor software to check if your application has been effective or not. After a day or two, you may want to stress-test it by running some high end application all together and monitor the temperature.
Abschluss
8 weitere Nutzer haben diese Anleitung absolviert.
Ikfixda
435 Reputation
1 Anleitung geschrieben
Diese Anleitung zum Öffnen und Ausbauen des Kühlers ist ebenfalls anwendbar für das Medion Akoya P6624 (MD98390)
Lutz - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 2
Letzten 7 Tage: 20
Letzten 30 Tage: 60
Insgesamt: 11,397
