Einleitung
Truck bushing affects the sensitivity of your skateboard turns and on road stability. Bushings wear down over time and need replacements. In this tutorial, we will replace the truck bushing on a Meepo Mini 5 electric skateboard.
Was du brauchst
Rotate the half-inch wrench counter-clockwise to loosen the bushing bolt.
Press the hanger back (wheels)
Press the wire and point the semicircular ridge to the hole at the same time as the space is narrow.
