Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Locate the 'OPEN' tab on the battery compartment. Pull the tab upwards and remove the cover using your finger. Remove the batteries.
    • Locate the 'OPEN' tab on the battery compartment.
    • Pull the tab upwards and remove the cover using your finger.
    • Remove the batteries.
  2. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  3. Locate the screws on the bottom of the device that hold the upper and lower halves together. Remove the (5) 19mm screws. Grasp the top and bottom and gently pull apart.
    • Locate the screws on the bottom of the device that hold the upper and lower halves together.
    • Remove the (5) 19mm screws.
    • Grasp the top and bottom and gently pull apart.
Abschluss
Shawn Vernon
135 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 18
