Zum Hauptinhalt wechseln
Memorex CD Alarm Clock Radio PCB Board Replacement
Was du brauchst
  1. Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: Schritt 1, Bild 1 von 3 Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: Schritt 1, Bild 2 von 3 Memorex CD Alarm Clock Radio PCB Board Replacement, Memorex CD Alarm Clock Radio: Schritt 1, Bild 3 von 3
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio PCB Board Replacement: Schritt 2, Bild 1 von 3 Memorex CD Alarm Clock Radio PCB Board Replacement: Schritt 2, Bild 2 von 3 Memorex CD Alarm Clock Radio PCB Board Replacement: Schritt 2, Bild 3 von 3
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio PCB Board Replacement, PCB Board: Schritt 3, Bild 1 von 1
    • Remove the (5) 7mm screws with a Phillips #1 screwdriver and a pair of tweezers.
    • Using a magnetic tip screwdriver will prevent screw loss.
  4. Memorex CD Alarm Clock Radio PCB Board Replacement: Schritt 4, Bild 1 von 3 Memorex CD Alarm Clock Radio PCB Board Replacement: Schritt 4, Bild 2 von 3 Memorex CD Alarm Clock Radio PCB Board Replacement: Schritt 4, Bild 3 von 3
    • Locate the wiring harness.
    • Disconnect the wiring harness using the tweezers.
  5. Memorex CD Alarm Clock Radio PCB Board Replacement: Schritt 5, Bild 1 von 1
    • Remove the PCB board from the device.
    • Replace the broken motherboard with a new PCB board.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 325
