Einleitung
Removing the PCB board requires a Phillips #1 screwdriver with at least a 15 cm shaft and a set of tweezers. Make sure there are no batteries in the device and that it is not plugged in before starting the procedure.
Was du brauchst
Turn the clock radio over so the bottom is facing up.
Pull the tab upward and remove the cover from the battery compartment.
Remove the batteries.
Remove the five screws on the bottom of the device with a screwdriver.
Grasp the top and bottom and gently pull apart.
Remove the (5) 7mm screws with a Phillips #1 screwdriver and a pair of tweezers.
Remove the PCB board from the device.
Replace the broken motherboard with a new PCB board.
