Zum Hauptinhalt wechseln
Einleitung
If you need to replace the back panel of the Minimove boombox, follow the steps from this guide. This guide will involve moderate disassembly of the device, including the removal of the back covering and base.
  1. Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
    • Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
    • It may be helpful to pull the plastic covers out with your fingers once the top of the cover has been revealed by using the plastic opening tool.
  2. This step will require at least a 30 mm Phillips #1 screwdriver.
    • This step will require at least a 30 mm Phillips #1 screwdriver.
    • Use a Phillips #1 screwdriver to remove the two 12 mm screws.
  3. The bottom panel screws and screw covers must be removed in order to access the back panel.
    • The bottom panel screws and screw covers must be removed in order to access the back panel.
    • Remove the four grey screw covers by inserting the plastic opening tool underneath the screw covers and rotating around the circumference.
    • The adhesive on the screw covers should be sticky enough to put the covers back on when re-assembling the device.
  4. Remove the two 8 mm screws with a Phillips #1 screwdriver.
    • Remove the two 8 mm screws with a Phillips #1 screwdriver.
    • Remove the two 12 mm screws with a long Phillips #1 screwdriver.
  5. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  6. To remove the back panel, use the plastic opening tool and gently work around the outline of the panel.  The outline wraps around the sides and can be spotted at the top back of the device. To remove the back panel, use the plastic opening tool and gently work around the outline of the panel.  The outline wraps around the sides and can be spotted at the top back of the device.
    • To remove the back panel, use the plastic opening tool and gently work around the outline of the panel. The outline wraps around the sides and can be spotted at the top back of the device.
  7. Be careful not to use too much force to remove the panel. The antenna wire is connected to the inside of the panel and may be damaged or ripped off if the panel is not gently removed. After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands. Carefully pull the panel off.
    • Be careful not to use too much force to remove the panel. The antenna wire is connected to the inside of the panel and may be damaged or ripped off if the panel is not gently removed.
    • After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands.
    • Carefully pull the panel off.
  8. Use a Phillips #1 screwdriver to detach the wire from the back panel by removing the 8 mm screw connecting the wire to the antenna.
    • Use a Phillips #1 screwdriver to detach the wire from the back panel by removing the 8 mm screw connecting the wire to the antenna.
  9. If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom. If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom.
    • If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom.
  10. Use the Phillips #1 screwdriver to remove the four 12 mm screws.
    • Use the Phillips #1 screwdriver to remove the four 12 mm screws.
    • Remove the five 6 mm screws at the top with the same screwdriver.
  11. Use a Phillips #1 screwdriver and remove the two vertical 8 mm screws from the top.
    • Use a Phillips #1 screwdriver and remove the two vertical 8 mm screws from the top.
  12. Pry open the inner back panel by inserting the plastic opening tool in the crack at the top corner. Use moderate force to pry it open and take the cover off.
    • Pry open the inner back panel by inserting the plastic opening tool in the crack at the top corner.
    • Use moderate force to pry it open and take the cover off.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Michael Johnson
237 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 2-9, Amido Winter 2014 Mitglied von Cal Poly, Team 2-9, Amido Winter 2014
CPSU-AMIDO-W14S2G9
5 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 486
