Zum Hauptinhalt wechseln
Mercedes W114/W115 Cluster Clock replacement and troubleshooting
Was du brauchst
  1. Mercedes W114/W115 Cluster Clock replacement and troubleshooting, Cluster Clock: Schritt 1, Bild 1 von 2 Mercedes W114/W115 Cluster Clock replacement and troubleshooting, Cluster Clock: Schritt 1, Bild 2 von 2
    • Locate the area that houses the clock. Unscrew the two barrels and place it aside.
    • Carefully pull out the clock without damaging any other parts.
  2. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: Schritt 2, Bild 1 von 3 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: Schritt 2, Bild 2 von 3 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: Schritt 2, Bild 3 von 3
    • Connect the screw (located behind the clock) to the negative supply of the battery, and then the small pin to the positive supply.
  3. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: Schritt 3, Bild 1 von 3 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: Schritt 3, Bild 2 von 3 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: Schritt 3, Bild 3 von 3
    • To check the clock, set the time to something you can remember and set it aside.
  4. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: Schritt 4, Bild 1 von 3 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: Schritt 4, Bild 2 von 3 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: Schritt 4, Bild 3 von 3
    • To check the power supply of the clock, locate the electrical connector and find the pin on it which supplies the power (12v) to the clock.
    • Take a small bulb and socket and bridge a wire from the 12v pin supplied from the electrical connector, to one of the two wires on the bulb and socket.
    • Next find a ground supply nearby ( the best place would be the key hole) and bridge another wire from it to the second available wire on the bulb and socket.
    • If the bulb lights up, it means your clock has power.
  5. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: Schritt 5, Bild 1 von 2 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: Schritt 5, Bild 2 von 2
    • If the bulb lights up, the power supply to the clock is good.
  6. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: Schritt 6, Bild 1 von 1
    • Before putting the clock in, clean the holder with a sand paper or a flat headed screw driver.
    • Start reassembling the dashboard by following the guide in reverse order.
    • While reassembling, be careful not to damage the wire harness , oil pressure meter hose, and temperature meter cable.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 6,444
