Einleitung
Dim picture? No display? Discolored output? No problem! Use this guide to replace the burnt light bulb with a new one. To complete this replacement, you will need the following parts ready:
Was du brauchst
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
Remove the light bulb from its housing unit.
Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
