Einleitung
Here's a chip identification summary for the Meta Quest Pro headset and controller.
Check out our Meta Quest Pro teardown for more details.
Special thanks to community member CChin for his contribution!
Einführungsvideo
Qualcomm SXR2155P Snapdragon XR2+ Applications Processor
Micron MT62F1536M64D8CL-026 WT:B 12 GB LPDDR5 SDRAM Memory
Western Digital SDINFDO4-256G 256 GB NAND Flash Memory (UFS)
Lattice Semiconductor LIF-MD6000-6 CrossLink FPGA
Qualcomm PM8150L Power Management
Cmedia CM7120 Audio DSP & CODEC Hub
Analog Devices MAX98360AENL 3.2 W Mono Class-D Audio Amplifier
Infineon CYPD3177 USB Type-C Port Controller
Qualcomm SMB1355 Li-Ion Battery Charger w/ Quick Charge 2.0/3.0/5.0
Qualcomm PM3003A Power Management
Texas Instruments TLC59401 16-Ch. LED Driver
Texas Instruments TS3USB221 USB 2.0 SPDT Analog Switch
Awinic AW37504CSR ? Dual Output Power Supply
Analog Devices MAX77827B 1.6 A Buck Boost Converter
Texas Instruments TPS62148 2.0 A step-down converter
Texas Instruments TPS61378-Q1 4.8 A synchronous boost converter
SG Micro SGM66056 2.2 MHz synchronous boost converter
OmniVision WS4694C 28 V over-voltage & over-current protection load switch
SG Micro SGM2578AAD 2 A load switch
Texas Instruments TLV7031 single comparator
Texas Instruments TLV9054 quad 5-MHz rail-to-rail operational amplifier
SG Micro SGM4T245 4-Bit Bus Transceiver
SG Micro SGM2045-1.20 300 mA / 1.2 V LDO regulator
SG Micro SGM2045-3.00 300 mA / 3.00 V LDO regulator
Nexperia 74AUP3G34 triple buffer
Nexperia 74LVC1G07 single buffer
NXP Semiconductor NX30P0121UK 3 A over-voltage protection
Awinic AW32710CSR over-voltage protection load switch
onsemi FSA4480UCX USB Type-C analog switch
SG Micro SGM4553 2-bit bidirectional voltage-level translator
OmniVision DPDT analog switch (possibly)
Murata LBEE5xx1WK ? type 1WK Bluetooth/WiFi module
Nordic Semiconductor nRF52840 Bluetooth 5.3 low-energy SoC
Qualcomm PM8250 power management
Qualcomm PM8150B power management
Qualcomm PMK8002 ? clock generator
Texas Instruments TCA6418E 18-bit I/O expander
Renesas SLG59M1717V 5 A load switch
Likely Texas Instruments LP5907UVE-1.2 250 mA / 1.2 V LDO regulator
DC-DC converter
Qualcomm SM6115 Snapdragon 662 Octa-Core applications/baseband processor
Samsung K4U8E3S4AD-MGCL 1 GB LPDDR4X SDRAM memory
Samsung KLM4G1FETE-B041 4 GB eMMC NAND flash memory
Qualcomm PMI632 power management
Microchip ATSAMD20G17 32-bit microcontroller
Renesas DA7281 haptic driver
Texas Instruments SN74AUC1G32 single 2-input OR gate
Nordic Semiconductor nRF52832 Bluetooth Low-Energy 5.3 SoC
Skyworks SKY66111-11 Bluetooth Low Energy front-end module
Probably Qorvo QPC8019Q DPDT RF switch
Qualcomm WCN3950 WLAN 802.11a/b/g/n/ac, Bluetooth 5.0, & FM radio
Allegro MicroSystems A1391 hall effect sensor
TDK-InvenSense ICM-42688-P 6-axis MEMS accelerometer & gyroscope
Analog Devices MAX98360A Class-D Audio Amplifier
Qualcomm SMB1355 Battery Charger
Ein Kommentar
Any photo-and-text-based teardown of the entire device like iFixit used to do? Love the company, but the fact that there aren't non-video articles on this under the Teardowns section is honestly a bit of a letdown. Would it be possible to bring them back? They're a really useful resource.
