Zum Hauptinhalt wechseln
Mi Airdots disassembly
Was du brauchst
  1. Mi Airdots disassembly, Case opening.: Schritt 1, Bild 1 von 3 Mi Airdots disassembly, Case opening.: Schritt 1, Bild 2 von 3 Mi Airdots disassembly, Case opening.: Schritt 1, Bild 3 von 3
    • With an opening pick we will leverage the edge between the interior part in which the earphones are placed and the exterior case. We will surround entire inner part with the opening pick until it comes out.
  2. Mi Airdots disassembly, Board disassembly: Schritt 2, Bild 1 von 2 Mi Airdots disassembly, Board disassembly: Schritt 2, Bild 2 von 2
    • We will unscrew the 3 screws that join the board to the part where we place the earphones (with a Phillips 00 screwdriver).
  3. Mi Airdots disassembly, Assembly: Schritt 3, Bild 1 von 2 Mi Airdots disassembly, Assembly: Schritt 3, Bild 2 von 2
    • The Mi Airdots case will be disassembled.
    • To assemble it, the screws are replaced as they are in step 2. We look to place the cables that connect the plate to the battery so that we do not crush them when we assemble the box.
Abschluss
To reassemble your device, follow these steps in reverse order.
13 weitere Personen haben diese Anleitung absolviert.
es en
100%
Hier starten ›
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 36
Letzte 30 Tage: 120
Insgesamt: 14,439
