Einleitung
Use this guide to remove or replace the pressure regulator on a MiTM Air Compressor AM1HE0205HD 2014.
Was du brauchst
Ensure the compressor is unplugged.
Flip the pressure switch lever up to the off position.
Pull the ring on the safety release valve away from the compressor tank to drain the air from the compressor.
Use a 3/4 inch wrench to loosen and remove the air hose quick-connect socket.
Use a 7/16 inch wrench to loosen and remove the pressure gauge.
Use a 5/8" wrench to loosen the air tank nipple from the air tank enough to be able to rotate it with the regulator.
Rotate the regulator 180°, so the bottom of the regulator faces away from the compressor motor.
With a 5/8 inch wrench bracing the air tank nipple, use a 3/4 inch wrench to loosen and remove the regulator.
