Einleitung
Follow the steps in this guide to remove and replace the motor/pump assembly of a Mi-T-M CM1400HDEC1 electric pressure washer.
Was du brauchst
Use a socket wrench to remove the four 47.9 mm-long 11 mm hex head bolts holding the motor in place from the bottom of the frame assembly.
Remove the zip ties holding the power cord to the frame assembly.
Fast fertig!
Abschluss
