Einleitung
Watch repairs at a jewelry store can be expensive, and not all places accept the same brands. However, a self-repair can save watch owners time and money and requires little knowledge to do. This battery replacement guide for a Michael Kors Hartman Rose Gold watch will provide step-by-step instructions to successfully deconstruct, replace, and reconstruct the watch and its battery.
Was du brauchst
Locate the spring pin under the band strap with the latch hole.
Insert a push-pin into the hole.
Push against the spring pin as needed until the band strap pops out.
Remove the spring pin.
Place a spudger into the small notch on the edge of the battery cover.
Pry the battery cover, using as much force as necessary.
Remove the cover and place it to the side.
Press firmly on the battery cover, using both of your thumbs to snap it back in place.
Re-insert the pin you removed into the hole of the smaller (lengthwise) folding segment.
Align both ends of the watch, holding the segment with the spring pin adjacent to the hole.
Use a spudger to press down on the spring pin, guiding it into the second hole.
Release once connecting segments are in place.
Place your wrist in the watch.
Relatch to ensure you correctly reassembled the watch.
Congratulations! You have replaced the battery from your Michael Kors Hartman Rose Gold watch. If you followed the step-by-step instructions, you should now have a fully reconstructed watch that is properly working. If it is not working properly, go back and carefully repeat the steps to ensure you completed everything correctly. Be sure to adjust the watch to display the correct time, and you will be ready to go.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
