Einleitung
Occasionally there are issues with the clasp where the watch will no longer connect to the other side of the watch due to the two metal push prongs becoming weak and flimsy. This guide will cover how to replace the spring that wedges in between those two prongs in order to make the watch wearable again.
Was du brauchst
Use the T3 screwdriver to remove the two 2mm screws in the device. The top metal panel should come off with ease once the screws have been removed.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
