Zum Hauptinhalt wechseln
Microsoft Kinect Tilt Motor Replacement
Was du brauchst
  1. Microsoft Kinect Tilt Motor Replacement, Tilt Motor: Schritt 1, Bild 1 von 1
    • Pull the rubber backing off the base of the Kinect.
    • If the adhesive attaching the rubber backing and the base doesn't come off with the rubber backing, remove the adhesive as well.
    • If the adhesive comes off separately, you may some type of adhesive to reattach the rubber backing.
  2. Microsoft Kinect Tilt Motor Replacement: Schritt 2, Bild 1 von 2 Microsoft Kinect Tilt Motor Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the four 7mm T6 Torx screws.
    • Pull off the base to reveal the inner case.
  3. Microsoft Kinect Tilt Motor Replacement: Schritt 3, Bild 1 von 3 Microsoft Kinect Tilt Motor Replacement: Schritt 3, Bild 2 von 3 Microsoft Kinect Tilt Motor Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the four 5mm #0 Phillip screws.
    • These screws strip easily.
    • Remove the metal plate to reveal the motor and gears.
    • Disconnect the connector to separate the plate from the Kinect.
  4. Microsoft Kinect Tilt Motor Replacement: Schritt 4, Bild 1 von 1
    • Remove the three gears on top of the motor, starting with the center gear.
  5. Microsoft Kinect Tilt Motor Replacement: Schritt 5, Bild 1 von 2 Microsoft Kinect Tilt Motor Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the four 5mm #00 Phillip screws.
    • Remove the motor from the plate to replace.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Daniel
341 Reputation
1 Anleitung geschrieben
Cal Poly, Team 14-7, Amido Spring 2015 Mitglied von Cal Poly, Team 14-7, Amido Spring 2015
CPSU-AMIDO-S15S14G7
4 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Be careful not to lose the spring & washer ! ( It’s also missing a step showing where the brass washer goes )https://www.zdnet.com/pictures/microsoft...
Bantum Works - Antwort
So far the isn’t a mention replacement of the plastic “post” that the tilt motor and the upper sensor unit are joined at. Mine broke (that’s what happens when you get a “free Xbox 360” at a neighborhood moving sale.) I couldn’t get the base plate apart as my T5 torx bit is trashed. So, my solution?…epoxy the heck out of the post as it’s only purpose is to hold the two units of the Kinect together. So far it worked!
David C - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 47
Insgesamt: 4,495
