Zum Hauptinhalt wechseln
Einleitung
How to disassemble Microsoft Lumia 435 and change / replace the broken LCD Display.
Einführungsvideo
  1. Switch off the phone. Remove the battery and any inserted SIM and memory cards. Use a screwdriver Torx T6 and remove the 4x black screws.
    • Switch off the phone.
    • Remove the battery and any inserted SIM and memory cards.
    • Use a screwdriver Torx T6 and remove the 4x black screws.
  2. There are several plastic locking clips hold the back cover to the frame. Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover. Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
    • There are several plastic locking clips hold the back cover to the frame.
    • Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
  3. Unhook: the touch screen flex cable the LCD Display flex cable
    • Unhook:
    • the touch screen flex cable
    • the LCD Display flex cable
    • Use a plastic tool lift up and remove the Logic board.
  4. This is the logic board / main board - a front and rear view. This is the logic board / main board - a front and rear view.
    • This is the logic board / main board - a front and rear view.
  5. The Display metal shield is locked to the frame by 4x locking clips. Use a tool with a sharp tip and careful unlock them and remove the shield. Use a tool with a sharp tip and careful unlock them and remove the shield.
    • The Display metal shield is locked to the frame by 4x locking clips.
    • Use a tool with a sharp tip and careful unlock them and remove the shield.
  6. The display is stuck tovthe touch screen glass with a double-sided adhesive tape. Use a hair dryer or hot air gun and worm the glass to make adhesive soften. Distort the frame a little and use a thin plastic tool to separate the display from the frame.
    • The display is stuck tovthe touch screen glass with a double-sided adhesive tape.
    • Use a hair dryer or hot air gun and worm the glass to make adhesive soften.
    • Distort the frame a little and use a thin plastic tool to separate the display from the frame.
  7. The display is very fragile, do the separation very carefully.
    • The display is very fragile, do the separation very carefully.
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
ZFix
178.781 Reputation
315 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
297 Mitglieder
983 Anleitungen geschrieben
كيف اقوم بفك الهاتف وفحص الخلل الذي يوجد فيه .اعني ان هاتفي لا يقبل العمل اظن انه محروق كيف افحصه ؟
How do I remove the phone and to inspect the defect in which the .ani there is a telephone that does not accept the work I think it's seared how it checked ?
mohammad7salaheddin - Antwort
I am pretty sure he didn’t use ifixit stuff to fix the screen, lmao
mario rados - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 2,951
