Einleitung
How to disassemble Microsoft Lumia 435 and remove / replace the logic board.
Was du brauchst
Einführungsvideo
Switch off the phone.
Remove the battery and any inserted SIM and memory cards.
Use a screwdriver Torx T6 and remove the 4x black screws.
There are several plastic locking clips hold the back cover to the frame.
Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
Unhook:
the touch screen flex cable
the LCD Display flex cable
Use a plastic tool lift up and remove the Logic board.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
كيف اقوم بفك الهاتف وفحص الخلل الذي يوجد فيه .اعني ان هاتفي لا يقبل العمل اظن انه محروق كيف افحصه ؟
How do I remove the phone and to inspect the defect in which the .ani there is a telephone that does not accept the work I think it's seared how it checked ?
I need dead boatd off lumia 435
Azhar from lahore chung
