Zum Hauptinhalt wechseln
Microsoft Lumia 640 XL Motherboard Replacement
Was du brauchst
  1. Microsoft Lumia 640 XL Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 Microsoft Lumia 640 XL Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 Microsoft Lumia 640 XL Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Place left palm on screen and right palm on the back.
    • Press down with fingertips and pull to separate the back from the screen.
    • You may hear cracking and popping.
  2. Microsoft Lumia 640 XL Motherboard Replacement: Schritt 2, Bild 1 von 2 Microsoft Lumia 640 XL Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Lift the battery away from the phone with the flat side of a spudger.
    • Be careful not to damage the battery.
  3. Microsoft Lumia 640 XL Motherboard Replacement, Headphone Jack: Schritt 3, Bild 1 von 3 Microsoft Lumia 640 XL Motherboard Replacement, Headphone Jack: Schritt 3, Bild 2 von 3 Microsoft Lumia 640 XL Motherboard Replacement, Headphone Jack: Schritt 3, Bild 3 von 3
    • Remove all ten T3, 4.09 mm screws.
    • Lift mid-frame assembly from phone with flat side of a spudger.
  4. Microsoft Lumia 640 XL Motherboard Replacement: Schritt 4, Bild 1 von 3 Microsoft Lumia 640 XL Motherboard Replacement: Schritt 4, Bild 2 von 3 Microsoft Lumia 640 XL Motherboard Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Lift and peel connector away from phone using tweezers.
    • To re-attach you may need E6000 Adhesive Glue.
  5. Microsoft Lumia 640 XL Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 2 Microsoft Lumia 640 XL Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Remove all three T3, 2.66 mm screws.
  6. Microsoft Lumia 640 XL Motherboard Replacement: Schritt 6, Bild 1 von 3 Microsoft Lumia 640 XL Motherboard Replacement: Schritt 6, Bild 2 von 3 Microsoft Lumia 640 XL Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Lift off connector with tweezers.
    • Lift motherboard off with tweezers and pull away with fingers.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Thanks, It was super
Yasmany - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 775
