Zum Hauptinhalt wechseln
Microsoft Lumia 640 XL Touch Screen Replacement
Was du brauchst
  1. Microsoft Lumia 640 XL Touch Screen Replacement, Battery: Schritt 1, Bild 1 von 3 Microsoft Lumia 640 XL Touch Screen Replacement, Battery: Schritt 1, Bild 2 von 3 Microsoft Lumia 640 XL Touch Screen Replacement, Battery: Schritt 1, Bild 3 von 3
    • Place left palm on screen and right palm on the back.
    • Press down with fingertips and pull to separate the back from the screen.
    • You may hear cracking and popping.
  2. Microsoft Lumia 640 XL Touch Screen Replacement: Schritt 2, Bild 1 von 2 Microsoft Lumia 640 XL Touch Screen Replacement: Schritt 2, Bild 2 von 2
    • Lift the battery away from the phone with the flat side of a spudger.
    • Be careful not to damage the battery.
  3. Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: Schritt 3, Bild 1 von 3 Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: Schritt 3, Bild 2 von 3 Microsoft Lumia 640 XL Touch Screen Replacement, Headphone Jack: Schritt 3, Bild 3 von 3
    • Remove all ten T3, 4.09 mm screws.
    • Lift mid-frame assembly from phone with flat side of a spudger.
  4. Microsoft Lumia 640 XL Touch Screen Replacement: Schritt 4, Bild 1 von 3 Microsoft Lumia 640 XL Touch Screen Replacement: Schritt 4, Bild 2 von 3 Microsoft Lumia 640 XL Touch Screen Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Lift and peel connector away from phone using tweezers.
    • To re-attach you may need E6000 Adhesive Glue.
  5. Microsoft Lumia 640 XL Touch Screen Replacement, Motherboard: Schritt 5, Bild 1 von 2 Microsoft Lumia 640 XL Touch Screen Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Remove all three T3, 2.66 mm screws.
  6. Microsoft Lumia 640 XL Touch Screen Replacement: Schritt 6, Bild 1 von 3 Microsoft Lumia 640 XL Touch Screen Replacement: Schritt 6, Bild 2 von 3 Microsoft Lumia 640 XL Touch Screen Replacement: Schritt 6, Bild 3 von 3
    • Lift off connector with tweezers.
    • Lift motherboard off with tweezers and pull away with fingers.
  7. Microsoft Lumia 640 XL Touch Screen Replacement, Touch Screen: Schritt 7, Bild 1 von 2 Microsoft Lumia 640 XL Touch Screen Replacement, Touch Screen: Schritt 7, Bild 2 von 2
    • Remove the screen from the device.
    • Touch screen digitizer and screen glass are one unit.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 1,308
