Zum Hauptinhalt wechseln
Microsoft Lumia 650 Battery Replacement
Was du brauchst
  1. Microsoft Lumia 650 Battery Replacement, Power off the device: Schritt 1, Bild 1 von 1
    • Press and hold the power button and swipe down to power off the device.
  2. Microsoft Lumia 650 Battery Replacement, Remove the back cover: Schritt 2, Bild 1 von 1
    • Remove the back cover by prying up from the bottom.
    • The back plastic is fairly bendable, but take care not to bend it too much while pulling it off the back.
  3. Microsoft Lumia 650 Battery Replacement, Remove the battery: Schritt 3, Bild 1 von 2 Microsoft Lumia 650 Battery Replacement, Remove the battery: Schritt 3, Bild 2 von 2
    • With the back of the phone removed, lift the battery from the top and remove it.
    • Always be careful with batteries, even if they seem protected. Store it in a safe place, or dispose of the old one properly.
    • You can now replace the battery.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Hayden Brown
410 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 36
Insgesamt: 839
