Zum Hauptinhalt wechseln
Microsoft Lumia 650 Motherboard Replacement
Was du brauchst
  1. Microsoft Lumia 650 Motherboard Replacement, Power off the device: Schritt 1, Bild 1 von 1
    • Press and hold the power button and swipe down to power off the device.
  2. Microsoft Lumia 650 Motherboard Replacement, Remove the back cover: Schritt 2, Bild 1 von 1
    • Remove the back cover by prying up from the bottom.
    • The back plastic is fairly bendable, but take care not to bend it too much while pulling it off the back.
  3. Microsoft Lumia 650 Motherboard Replacement, Remove the battery: Schritt 3, Bild 1 von 2 Microsoft Lumia 650 Motherboard Replacement, Remove the battery: Schritt 3, Bild 2 von 2
    • With the back of the phone removed, lift the battery from the top and remove it.
    • Always be careful with batteries, even if they seem protected. Store it in a safe place.
  4. Microsoft Lumia 650 Motherboard Replacement, Remove the SIM card and SD card: Schritt 4, Bild 1 von 1
    • If present, remove the SIM card and the SD card from beside the battery slot.
    • To remove the SD card, pull it out with your fingernail.
    • To remove the SIM card, push in on it and pull it out.
  5. Microsoft Lumia 650 Motherboard Replacement, Remove the back screws: Schritt 5, Bild 1 von 1
    • Remove the 12 Torx T4 screws from the back panel of the phone.
  6. Microsoft Lumia 650 Motherboard Replacement, Remove the back panel: Schritt 6, Bild 1 von 2 Microsoft Lumia 650 Motherboard Replacement, Remove the back panel: Schritt 6, Bild 2 von 2
    • Pry up around the panel to remove it from the phone.
    • There is a small clip, marked in red, just next to the battery connectors on the panel which is very easy to break.
  7. Microsoft Lumia 650 Motherboard Replacement, Disconnect cameras: Schritt 7, Bild 1 von 1
    • Disconnect the cameras from the motherboard.
    • Disconnect the rear-facing camera connector and remove the camera from the phone.
    • Disconnect the front-facing camera connector and remove the camera from the phone. It is held in with a small amount of adhesive, but you should be able to pull it out.
    • You can now replace these parts.
  8. Microsoft Lumia 650 Motherboard Replacement, Disconnect ribbon cables: Schritt 8, Bild 1 von 1
    • Disconnect the remaining ribbon cables from the motherboard.
    • Disconnect the display ribbon cable.
    • Disconnect the top I/O, earpiece and proximity sensor ribbon cable.
  9. Microsoft Lumia 650 Motherboard Replacement, Remove the motherboard: Schritt 9, Bild 1 von 1
    • Moving the ribbon cables to one side, you can now remove the motherboard.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Hayden Brown
410 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 28
Insgesamt: 894
