Einleitung
If the speaker is not playing at its optimal level or the audio output seems to be malfunctioning , the speakers most likely need to be changed. Use this guide to replace the speakers in your Microsoft Surface 2 . Make sure to use a standard nylon spudger and not a metal one.
Was du brauchst
Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
Use a plastic spudger to pry the retaining clip away from the display cable.
Carefully pull the ribbon cable from its socket on the motherboard.
Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
Once all screws have been removed, lift and remove the bezel from the rest of the device.
Using a T3 screwdriver, unscrew and remove the 3.5mm screws holding down the silver plates located at the corners of the device.
Using tweezers, remove the cable connecting the speaker to the motherboard.
Peel up the tiny strip of yellow tape securing the cable to the motherboard.
Lifting from the inmost end of the speaker, use a spudger to carefully pry the speaker from the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
