Einleitung
Replacing the kickstand is one of the simplest things to fix in a Surface 3. However, you will still need to take off the display and remove the battery to fully access the parts to replace.
Was du brauchst
Warm up an iOpener following the instructions found in the iOpener guide.
Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
Now that you've gotten the casing off of the Surface 3, you can start removing the battery pack.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Slide the iFixit plastic cards under the compartments of the battery pack.
Slide the card around to undo the adhesive under the battery pack
Carefully slide the battery's flat power and data connector from its insert.
You may now switch out the battery pack for a new one.
Remove these four 3/16" Torx #5 screws that hold in the hinges to replace the hinges.
These two retaining tabs need to be fed through the slots in the case to release the kickstand.
Use picks to make the tab slide through the slot then simply pull out the kickstand,
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Please can you tell me which kickstand the surface pro 3 64 GB (2013) needs? Is it the same as the surface pro 4 ? I have broken the stand and am trying yo source a replacement.
