Einleitung
Follow this guide to remove or replace a faulty USB port assembly on a Microsoft Surface Book.
This procedure requires you to remove the back panel. Note: It’s not necessary to remove the SD card to get to the USB ports.
Was du brauchst
Press and hold the Detach button on the keyboard.
Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
Remove the display.
Flip open the display as far as it will go.
Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
Firmly push the paper clip into the hole.
Pull the base away from the display to detach it.
With one side detached, pull firmly to pivot the display out to disconnect the second side.
Insert the plastic opening tool in the crevice between the panel and the keyboard.
Apply some pressure and lift up so that the back panel is pried away from the keyboard.
Continue to lift until the panel is completely separated from the keyboard.
Lift the panel away with the ribbon cable still attached and set aside the panel so that you can work on other components.
Orient your keyboard with the internals facing up and the USB Port on the right.
Lift up the black and gold wires and find the screw hidden there.
Use the T3 Torx Screwdriver and remove the four mm screw.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
How do you re-glue the bottom cover back on?
Where do you get the replacement USB board? Is there’s a part number for it that I can look up?
Can the same be done for the type c port
There are quite a few questions raised Tunnel Rush. Maybe I missed a few details in the manual.
