Einleitung
The Microsoft Surface Headphones headband cushion allows for a comfortable listening experience. If you've noticed that the cushioning doesn't seem so comfortable anymore, it might be time to replace it. This guide will show you how to do just that!
Was du brauchst
Starting at the peak of the headband, push inward below the seam, between the plastic headband and cushion, to create a gap.
Work your way down the headband until the cushion is exposed.
Use a metal spudger to carefully pry the rest of the cushion cover away from the plastic headband.
Remove the cushion cover.
There is tape at either end of the cushion; remove the tape.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
How do you put back the the cushion cover?
