Zum Hauptinhalt wechseln
Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement
Was du brauchst
  1. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 1 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 2 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 3 von 3
    • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Flip your laptop over: Schritt 2, Bild 1 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Flip your laptop over: Schritt 2, Bild 2 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Flip your laptop over: Schritt 2, Bild 3 von 3
    • Close your laptop and lay it down so the rubber feet are facing up.
  3. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the feet: Schritt 3, Bild 1 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the feet: Schritt 3, Bild 2 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the feet: Schritt 3, Bild 3 von 3
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
  4. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case screws: Schritt 4, Bild 1 von 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case screws: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $36.95
    • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
  5. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Detach the lower case: Schritt 5, Bild 1 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Detach the lower case: Schritt 5, Bild 2 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Detach the lower case: Schritt 5, Bild 3 von 3
    • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
    • Don't insert the pick near the outer edges or you'll damage the antenna bar.
  6. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: Schritt 6, Bild 1 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: Schritt 6, Bild 2 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: Schritt 6, Bild 3 von 3
    • Twist the pick to lift the lower case enough that you can grip it with your hand.
  7. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case: Schritt 7, Bild 1 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case: Schritt 7, Bild 2 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the lower case: Schritt 7, Bild 3 von 3
    • Lift the lower case and remove it.
  8. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the battery: Schritt 8, Bild 1 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the battery: Schritt 8, Bild 2 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the battery: Schritt 8, Bild 3 von 3
    • Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
  9. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: Schritt 9, Bild 1 von 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: Schritt 9, Bild 2 von 2
    • Use tweezers or your fingers to remove the battery connector cover.
  10. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: Schritt 10, Bild 1 von 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: Schritt 10, Bild 2 von 2
    • Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It may take a few tries to align the connector—don't try to force it into place.
  11. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the speaker: Schritt 11, Bild 1 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the speaker: Schritt 11, Bild 2 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Disconnect the speaker: Schritt 11, Bild 3 von 3
    • The left speaker will be on your right-hand side, since the laptop is laying upside down.
    • Slide the point of a spudger under the left speaker connector and gently lift it straight up and out of the socket.
    • Don't lift on the cables themselves, or you may damage them.
    • During reassembly, hold the connector over its socket and press down gently with the flat end of a spudger until it clicks into place. If you're having trouble, don't try to force the connector into its socket—reposition it and try again.
  12. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the speaker: Schritt 12, Bild 1 von 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Remove the speaker: Schritt 12, Bild 2 von 2
    • Use a Torx Plus 3IP screwdriver to remove the two 3.2 mm‑long screws securing the left speaker.
  13. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: Schritt 13, Bild 1 von 2 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement: Schritt 13, Bild 2 von 2
    • Remove the speaker.
    • During reassembly, place the speaker onto the frame so the grommets on the right edge go over their screw posts.
  14. Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Reassembly information: Schritt 14, Bild 1 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Reassembly information: Schritt 14, Bild 2 von 3 Microsoft Surface Laptop 7 (13.8-inch) Left Speaker Replacement, Reassembly information: Schritt 14, Bild 3 von 3
    • Make sure your replacement speaker has two rubber grommets installed on its right edge.
    • If it doesn't, remove the grommets from your old speaker and install them in your replacement.
    • Installing these can be tricky. Use your fingers to pinch the grommet and slide it into its notch.
Abschluss
Spencer Day
165.294 Reputation
1.047 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
124 Mitglieder
24.294 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 47
Insgesamt: 496
