Einleitung
Follow this guide to replace the Surface Connect port (aka Surflink) in your Microsoft Surface Laptop 7 (13.8‑inch).
You may need to replace the Surface Connect port if your laptop only charges when the cable is held in a certain position or if the connection is loose.
Before replacing the Surface Connect port, try using another charger to make sure the issue is with the port itself and not your current charger.
Was du brauchst
Unplug all cables and fully shut down your laptop.
Close your laptop and lay it down so the rubber feet are facing up.
Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
Use your tweezers to pry up and remove the foot.
Repeat the process to remove the remaining feet.
In diesem Schritt verwendetes Werkzeug:FixMat$36.95
Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
Twist the pick to lift the lower case enough that you can grip it with your hand.
Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
Use the flat end of a spudger to flip up the metal buckle on the Surface Connect port connector.
Use tweezers or your fingers to grip the Surface Connect port cable and pull it straight out of its socket.
Reconnect the Surface Connect port cable.
Remove any adhesive liners and press the cable into place to secure it with the adhesive.
Use a Torx Plus 3IP screwdriver to remove the two 3 mm‑long screws securing the Surface Connect port to the top left corner of the frame.
Heat an iOpener and lay it on the Surface Connect port cable for two minutes to soften the adhesive.
In diesem Schritt verwendetes Werkzeug:Tesa 61395 Tape$2.99
Grip the Surface Connect cable close to the motherboard connector and peel the cable from the fan.
If the tape is still sticky, you don't need to replace it.
If the adhesive is no longer sticky, or if you're replacing the fan and it doesn't have adhesive, apply a new strip of thin, double-sided tape to the top edge of the fan.
Lift and remove the Surface Connect port.
Put the Surface Connect port into place so its cutouts go over their posts on the motherboard. Make sure the port is fully in its cutout—the outer edge should be flush with the frame.
Install the two screws that secure the port.
