Was du brauchst
Qualcomm X1P-64-100-103 Snapdragon X Plus deca-core applications processor
SK hynix H58G56BK8BX068 4 GB LPDDR5X SDRAM Memory
Qualcomm PMC8380-001-00 power management
Qualcomm PMC8380VE-001 power management
Qualcomm PMC1010H-001-07 charge pump & buck regulator
Qualcomm PMC1010H-001-08 charge pump & buck regulator
Qualcomm power management
Monolithic Power Systems MP2322 1 A synchronous step-down converter
Richtek RT5753ALGQW 3 A synchronous step-down converter
Monolithic Power Systems DC-DC converter
Nexperia 74LVC2G66 dual SPST analog switch
Texas Instruments TPS22964C 3 A load switch
Diodes Incorporated AP22653FDZ-7 adjustable current-limited power distribution switch
NXP Semiconductors NX3P1108UK high-side power switch
Toshiba TCR3UM18A 300 mA / 1.8 V LDO regulator
Texas Instruments SN74LV1T08 single 2-input AND gate
Diodes Incorporated 74AUP1G08FS3 single 2-input AND gate
Qualcomm WCN7851-501 FastConnect 7800 WiFi 7 & Bluetooth 5.4 controller
Qualcomm 2.4 GHz front-end module
Qualcomm 5 GHz front-end module
NXP Semiconductors MIMXRT633SFFOB 32-bit ARM Cortex-M33 microcontroller w/ Xtensa HiFi4 audio DSP
Winbond W25Q512NW 64 MB serial NOR flash memory
Macronix MX25U1633FZUI 2 MB serial NOR flash memory
Renesas mixed signal array
Likely Qualcomm camera power management
NXP Semiconductors NX20P0407UK USB type-C port protector
Analog Devices MAX4983EEVB+ USB 2.0 DPDT analog switch
Vishay DG2723 dual SPDT analog switch
onsemi FPF2495CUCX 28 V over-voltage & over-current protection load switch
Diodes Incorporated AP22800HB-7 programmable load switch
NXP Semiconductors PCA9306 2-bit voltage-level translator
Nexperia 74AVC2T245 2-bit level shifter
Nexperia 74LV1T08GX single 2-input AND gate
STMicroelectronics LSM6DSO 6-axis accelerometer & gyroscope
STMicroelectronics LIS2DW12 3-axis accelerometer
MEMSIC MMC5633NJL 3-axis magnetometer
