Was du brauchst
Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
Slowly work the tool around the entire edge of the screen.
Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
Allow the glue to cool before letting it come into contact with any other surface.
Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
Remove the 22 screws on the bezel.
Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
Once the brackets are removed, set them aside.
Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
Remove the ribbon that the spudger is touching in the picture.
Remove the front-facing camera.
If you have not done so yet, follow the steps here: Microsoft Surface Pro 2 Motherboard Replacement Guide.
