Einleitung
If your kickstand has worn out or broken and is no longer supporting your device, use this guide to replace it. You may need to replace the kickstand due to normal wear-and-tear or an accidental drop. The process is very simple and doesn’t require taking the Surface Pro 3 apart. You’re just removing and replacing the kickstand itself.
Was du brauchst
Wiggle the kickstand gently back and forth to disengage the two lightly-adhered tabs connecting the center of the kickstand to the main body.
Remove the kickstand from the back cover of the Surface Pro 3.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
The title for this repair guide is incorrect. This is for the kickstand, not the battery.
Hi Michael, thanks for catching this! It looks like someone changed it and it was ok’d on accident. We’ve changed it back.
