Einleitung
This guide will teach you how to safely remove your rear camera from you Surface Pro 3. The guide starts by removing the screen and digitizer and then goes right into removing the rear-facing camera.
Was du brauchst
To remove the display, first soften the adhesive by applying heat. You can use a heat pad, heat gun, or iOpener. In a pinch, a hair dryer can also work.
Steadily and evenly heat the perimeter of the display until it's too hot to touch, and try to maintain that temperature for several minutes.
Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
Carefully insert an opening pick into the gap between the screen and the device to cut the adhesive.
Slide the pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
Continue to heat sections of the screen with the heat gun.
As you make your way around the screen with the heat gun, use the plastic opening tool and the opening picks to pry the screen loose.
Remove the 3 mm T3 Torx screw securing the battery connector, and disconnect the battery connector.
Remove the single 4 mm T3 Torx screw securing the display cable.
Lift the connector to disconnect the cable.
Grasp the orange cable connected to the silver connecter.
Carefully lift the orange cable up until the connecter pops off.
The screen will now be completely disconnected.
Remove the 4mm screw with the T3 Torx Screwdriver.
Remove the four 7mm screws with the T3 Torx Screwdriver.
Locate the black piece shown.
Remove this piece by gently lifting it up with the tweezers until it pops off.
2 weitere Personen haben diese Anleitung absolviert.
