Einleitung
Use this guide to replace the left and right speakers in the Microsoft Surface Pro.
Was du brauchst
Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
Apply a suction cup as close as possible to the edge of the display.
Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
Starting from the top edge, lift the display slightly. If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
Before completely removing the display, disconnect the three display cables.
Unscrew all the 23 screws located on the outside panel with the T5 torx screw driver
Use the T5 torx screw driver to unscrew the 6 T5 screws located on the left and right metal panels
Use the T2 torx screw driver to unscrew the 23 T2 screws located on the left and right metal panels
Disconnect the two speakers with tweezers
Gently pry out the speakers with spudger
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
