Zum Hauptinhalt wechseln
Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement
Was du brauchst
  1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: Schritt 1, Bild 1 von 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: Schritt 1, Bild 2 von 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: Schritt 1, Bild 3 von 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: Schritt 2, Bild 1 von 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: Schritt 2, Bild 2 von 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: Schritt 2, Bild 3 von 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: Schritt 3, Bild 1 von 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: Schritt 3, Bild 2 von 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: Schritt 3, Bild 3 von 3
    • Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering.
    • Use tweezers to push these tabs in.
    • Gently pull the plastic covering off of the upper lid.
  4. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: Schritt 4, Bild 1 von 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: Schritt 4, Bild 2 von 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: Schritt 4, Bild 3 von 3
    • Grab the plastic wire housing near the serial port.
    • Gently pull and jiggle the wire housing until it comes free from the circuit board.
  5. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: Schritt 5, Bild 1 von 2 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: Schritt 5, Bild 2 von 2
    • Gently lift up the bulbs and remove the wires from the plastic.
    • After completely freeing the bulbs, buy new ones and replace.
Abschluss
Cal Poly, Team 6-9, Regan Fall 2011 Mitglied von Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,149
