Einleitung
For this guide, you will be replacing the device's camera. You will need to be mindful and careful of the device's other exposed components when following this guide.
Was du brauchst
Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
Near the top left of the device, gently unclip the gold ribbon cable by pulling up the black clip holding it in place and removing the ribbon.
Remove the old camera by carefully lifting it straight up.
Place the new camera in its place.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
