Einleitung
This is a guide to replace the speaker in the device. Make sure to follow all the steps correctly and handle with care.
Was du brauchst
Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
Follow the black and red wires coming from the white back plate to the motherboard.
Carefully use the soldering iron to desolder the wires from the motherboard.
Use the nylon spudger to gently pry the speaker from the case. Then put the new speaker in.
