Zum Hauptinhalt wechseln
Midea MRU03M2ABB Upright Freezer Door Replacement
Was du brauchst
  1. Midea MRU03M2ABB Upright Freezer Door Replacement, Door: Schritt 1, Bild 1 von 2 Midea MRU03M2ABB Upright Freezer Door Replacement, Door: Schritt 1, Bild 2 von 2
    • Unplug the device.
    • Only unplug when your hand is dry.
  2. Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 2, Bild 1 von 1
    • Empty the shelves.
  3. Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 3, Bild 1 von 3 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 3, Bild 2 von 3 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 3, Bild 3 von 3
    • Use a plastic spatula to remove the hinge cover on top of the freezer.
    • Pushing at the pointy part of the cover makes it easier to remove.
  4. Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 4, Bild 1 von 3 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 4, Bild 2 von 3 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 4, Bild 3 von 3
    • Unscrew the hinge counterclockwise.
  5. Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 5, Bild 1 von 2 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 5, Bild 2 von 2
    • Lift the hinge out of the freezer and the door.
  6. Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 6, Bild 1 von 3 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 6, Bild 2 von 3 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 6, Bild 3 von 3
    • With two hands, gently hold and open the door as usual.
    • Lift the door up to remove it from the bottom hinge.
    • You have completely detached the door from the freezer.
  7. Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 7, Bild 1 von 3 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 7, Bild 2 von 3 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 7, Bild 3 von 3
    • With the new door, locate the hole underneath the door.
    • Using two hands, gently place the door on top of the hinge (the pointy part of the hinge should fit inside the hole).
    • Close the door.
  8. Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 8, Bild 1 von 3 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 8, Bild 2 von 3 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 8, Bild 3 von 3
    • Use your hand to align the door so these three screw holes stay on the same line.
    • Carefully place the top hinge to fit these holes.
  9. Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 9, Bild 1 von 2 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 9, Bild 2 von 2
    • Thread and tighten the screws clockwise.
    • Gently swing the door to make sure it operates well.
  10. Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 11, Bild 1 von 2 Midea MRU03M2ABB Upright Freezer Door Replacement: Schritt 11, Bild 2 von 2
    • Finally, firmly press the cover onto the hinge to secure it. Now, you have completely replaced the door.
    • A "click" will indicate that the cover is finally in its place.
Ziellinie
Thinh Lang
193 Reputation
1 Anleitung geschrieben
York University, Team 1-31, O'Regan Winter 2024 Mitglied von York University, Team 1-31, O'Regan Winter 2024
YORK-O'REGAN-W24S1G31
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 39
Insgesamt: 149
