Einleitung
This guide will help you to replace the door of the Midea MRU03M2ABB Upright Freezer.
A damaged or malfunctioning freezer door can compromise the efficiency of your appliance, leading to potential energy waste, food waste, and diminished performance.
Before embarking on this task, I recommend familiarizing yourself with the provided steps, as well as ensuring you have the necessary tools and replacement parts in hand. Also, be sure to unplug your freezer and store your food in a cooler before you begin so you can work and your food will not defrost.
Was du brauchst
With two hands, gently hold and open the door as usual.
Lift the door up to remove it from the bottom hinge.
With the new door, locate the hole underneath the door.
Using two hands, gently place the door on top of the hinge (the pointy part of the hinge should fit inside the hole).
Close the door.
Use your hand to align the door so these three screw holes stay on the same line.
Carefully place the top hinge to fit these holes.
Finally, firmly press the cover onto the hinge to secure it. Now, you have completely replaced the door.
