Einleitung
This guide will display the step-by-step process of fixing and/or replacing a faulty antenna. Soldering may be involved, so be prepared!
Was du brauchst
First, apply pressure with your thumb on the top of the battery cover.
Next, pull down on the cover until it begins to slide.
Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
Carefully and slowly lift the motherboard away from the front case. The motherboard will be attached to the speaker, which is firmly glued onto the front case.
Check the connection of the antenna with your eyes and fingers. The connection should be firm and smooth where it was soldered.
Ensure that the spring of the antenna isn't crooked or damaged by rubbing your fingers along the length of the spring.
After obtaining a new or undamaged spring, solder it back onto the circuit board. Again, this is a delacate process as the soldering tool will be hot!
5 weitere Nutzer:innen haben diese Anleitung absolviert.
