Zum Hauptinhalt wechseln
Milwaukee 2780-20 (2) Ball Bearings Replacement
Was du brauchst
  1. Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: Schritt 1, Bild 1 von 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: Schritt 1, Bild 2 von 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, Trigger Assembly: Schritt 1, Bild 3 von 3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 2, Bild 1 von 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 2, Bild 2 von 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 2, Bild 3 von 3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 3, Bild 1 von 1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 4, Bild 1 von 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 4, Bild 2 von 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 4, Bild 3 von 3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
  5. Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: Schritt 5, Bild 1 von 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: Schritt 5, Bild 2 von 3 Milwaukee 2780-20 (2) Ball Bearings Replacement, (2) Ball Bearings: Schritt 5, Bild 3 von 3
    • Using a Torx T20 screwdriver to remove four 6mm screws located on top of the gearcase assembly.
  6. Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 6, Bild 1 von 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 6, Bild 2 von 2
    • Pull the gearcase away from electronic assembly to expose the inside.
  7. Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 7, Bild 1 von 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 7, Bild 2 von 2
    • Using a 3/8 Wrench, Remove the nut located in the center of the Gearcase.
    • The nut and pinion should immediatley come apart from the rotor assembly.
  8. Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 8, Bild 1 von 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 8, Bild 2 von 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 8, Bild 3 von 3
    • Pull the rotor assembly apart from the gearcase casing.
  9. Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 9, Bild 1 von 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 9, Bild 2 von 3 Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 9, Bild 3 von 3
    • Using a Torx T15 screwdriver, remove the two 4mm screws to take the bearing retainer off.
  10. Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 10, Bild 1 von 2 Milwaukee 2780-20 (2) Ball Bearings Replacement: Schritt 10, Bild 2 von 2
    • Use a hammer to knock out the bearing and begin installing the new one before reassembling.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 44
Insgesamt: 2,989
