Zum Hauptinhalt wechseln
Milwaukee 2780-20 Trigger Assembly Replacement
Was du brauchst
  1. Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: Schritt 1, Bild 1 von 3 Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: Schritt 1, Bild 2 von 3 Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: Schritt 1, Bild 3 von 3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
  2. Milwaukee 2780-20 Trigger Assembly Replacement: Schritt 2, Bild 1 von 3 Milwaukee 2780-20 Trigger Assembly Replacement: Schritt 2, Bild 2 von 3 Milwaukee 2780-20 Trigger Assembly Replacement: Schritt 2, Bild 3 von 3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
  3. Milwaukee 2780-20 Trigger Assembly Replacement: Schritt 3, Bild 1 von 1
    • Pull apart the housing handles.
  4. Milwaukee 2780-20 Trigger Assembly Replacement: Schritt 4, Bild 1 von 3 Milwaukee 2780-20 Trigger Assembly Replacement: Schritt 4, Bild 2 von 3 Milwaukee 2780-20 Trigger Assembly Replacement: Schritt 4, Bild 3 von 3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 22
Insgesamt: 1,184
