Einleitung
This guide will show you how to replace the diaphragm assembly. A faulty diaphragm assembly can lead to a few different issues including irregular shaking, grinding, or leaking grease.
Was du brauchst
Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
Now that you have loosened the diaphragm, you can now pull it out of the gear case.
After removing some grease (if needed), remove the two 15mm T20 Torx screws shown in red.
Remove the metal piston from the diaphragm assembly.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
to reasemble .
Which is the correct position of the Shift knob assembly ?
