Einleitung
In this guide, you will get a step by step basis on replacing the fan baffle. You will need to remove 4 screws in order to get to the fan baffle, this guide will show you where exactly these screws are.
Was du brauchst
Now the two 10mm T-10 screws shown in red can be removed.
Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
Remove the four 37mm T-20 screws shown in red. These screws attach the gear housing to the motor housing.
Remove the four 12mm screws with a T-15 Torx screwdriver shown in red.
These screws hold the fan baffle in place.
