Einleitung
If you need to replace the motor housing in the rotary hammer, use this guide to take apart the device. You will be following a step by step guide, that will help you in replacing the motor house, you may also refer to the pictures attached to each step for guidance.
Was du brauchst
Now the two 10mm T-10 screws shown in red can be removed.
Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
Remove the four 37mm T-20 screws shown in red. These screws attach the gear housing to the motor housing.
Remove the four 12mm screws with a T-15 Torx screwdriver shown in red.
These screws hold the fan baffle in place.
Pull the black wire(shown in the image) out of the trigger assembly.
Using a metal spudger slide the black wire (shown in the image) out of the trigger assembly.
Using a metal spudger slide the yellow wire (shown in the image) out of the trigger assembly.
After disconnecting the wires, push the 120v Field Assembly out of the motor housing.
