Zum Hauptinhalt wechseln
Milwaukee 5262-21 Reduction Gear Assembly Replacement
Was du brauchst
  1. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Housing Assembly: Schritt 1, Bild 1 von 1
    • Remove the ten 19mm T20 Torx screws shown in red.
  2. Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 2, Bild 1 von 1
    • Remove the red Housing Assembly by lifting it up off of the tool.
  3. Milwaukee 5262-21 Reduction Gear Assembly Replacement, Reduction Gear Assembly: Schritt 3, Bild 1 von 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement, Reduction Gear Assembly: Schritt 3, Bild 2 von 2
    • Remove the two 10mm T-10 Torx screws that attach the top brush holders to the motor housing.
    • Remove the two 10mm T-10 Torx screws that attach the bottom brush holders to the motor housing.
  4. Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 4, Bild 1 von 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 4, Bild 2 von 2
    • Using a metal spudger, pry off each brush holder.
  5. Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 5, Bild 1 von 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 5, Bild 2 von 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 5, Bild 3 von 3
    • Remove the four 37mm T20 Torx screws shown in red.
  6. Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 6, Bild 1 von 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 6, Bild 2 von 2
    • Pull the front portion of the tool out from the motor housing.
  7. Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 7, Bild 1 von 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 7, Bild 2 von 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 7, Bild 3 von 3
    • Remove the two 11.5mm T10 Torx screws shown in red.
  8. Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 8, Bild 1 von 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 8, Bild 2 von 2
    • Pull the 120V armature assembly out of the diaphragm assembly.
  9. Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 9, Bild 1 von 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 9, Bild 2 von 2
    • Using a metal spudger, pry the diaphgram assembly out of the gear case.
  10. Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 10, Bild 1 von 2 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 10, Bild 2 von 2
    • Now that you have loosened the diaphragm, you can now pull it out of the gear case.
  11. Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 11, Bild 1 von 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 11, Bild 2 von 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 11, Bild 3 von 3
    • The diaphragm assembly will be lathered in grease. In order to move forward, you may want to give it a wipe down to remove any extra grease.
    • After removing some grease (if needed), remove the two 15mm T20 Torx screws shown in red.
  12. Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 12, Bild 1 von 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 12, Bild 2 von 3 Milwaukee 5262-21 Reduction Gear Assembly Replacement: Schritt 12, Bild 3 von 3
    • Now pull the reduction gear assembly up and out of the diaphragm.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Payton Parker
534 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G3, Botvin Spring 2019 Mitglied von UMass Dartmouth, Team S1-G3, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 13
Insgesamt: 1,352
