Zum Hauptinhalt wechseln
Milwaukee 6130-33 Safety Brush Springs Replacement
Was du brauchst
  1. Milwaukee 6130-33 Safety Brush Springs Replacement, Wiring System: Schritt 1, Bild 1 von 2 Milwaukee 6130-33 Safety Brush Springs Replacement, Wiring System: Schritt 1, Bild 2 von 2
    • Hold the device with the cord facing upwards and the bottom side facing down.
    • Remove the 4 mm TR20 Torx screws from the exterior case.
  2. Milwaukee 6130-33 Safety Brush Springs Replacement: Schritt 2, Bild 1 von 2 Milwaukee 6130-33 Safety Brush Springs Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 4 mm TR20 Torx screws to detach the clamp from the cord set.
  3. Milwaukee 6130-33 Safety Brush Springs Replacement: Schritt 3, Bild 1 von 3 Milwaukee 6130-33 Safety Brush Springs Replacement: Schritt 3, Bild 2 von 3 Milwaukee 6130-33 Safety Brush Springs Replacement: Schritt 3, Bild 3 von 3
    • Remove the two 3.5 mm TR10 Torx screws to access the wiring.
    • Wiring can be damage or worn, take caution when handling the wires.
  4. Milwaukee 6130-33 Safety Brush Springs Replacement, Safety Brush Springs: Schritt 4, Bild 1 von 3 Milwaukee 6130-33 Safety Brush Springs Replacement, Safety Brush Springs: Schritt 4, Bild 2 von 3 Milwaukee 6130-33 Safety Brush Springs Replacement, Safety Brush Springs: Schritt 4, Bild 3 von 3
    • Remove both 3.5 mm TR10 Torx screws from the carbon brush locks.
    • Turn over the device and perform the same process on the opposite side.
  5. Milwaukee 6130-33 Safety Brush Springs Replacement: Schritt 5, Bild 1 von 2 Milwaukee 6130-33 Safety Brush Springs Replacement: Schritt 5, Bild 2 von 2
    • Remove both springs by pulling outwards from the rotor.
    • When removing, pull on the carbon casing to avoid harming both yourself and the device.
  6. Milwaukee 6130-33 Safety Brush Springs Replacement: Schritt 6, Bild 1 von 2 Milwaukee 6130-33 Safety Brush Springs Replacement: Schritt 6, Bild 2 von 2
    • Using a pair of pliers, squeeze the black cord.
    • Remove by pulling the black wire attached to the brush casing.
Abschluss
Brandon Olguin
509 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 60
