Einleitung
This guide will demonstrate how to replace the Battery on the Milwaukee Hex Impact Driver 2656-20. The step will cover the technique of removing the battery. There are no tools required. The repair is considered Very in difficulty and will take approximately 30 seconds.
Squeeze the red buttons on the battery.
While squeezing the red buttons, slide the battery forward and out to remove it from the device.
Ein Kommentar
Replacement Power Tool Battery for Milwaukee 2656-20
Type: Li-ion
Volt: 18V
Capacity: 6000mAh
Color: Red
Weight: 978g
Dimension: 141.15 x 78.00 x 73.95mm
Milwaukee 2656-20 Power Tool Batteries are made from the highest quality parts and are compatible with the Milwaukee cordless tools. Go to view more about this battery on https://www.drill-batteries.com/batteryp...
