Zum Hauptinhalt wechseln
Milwaukee Hex Impact Driver 2656-20 Case Disassembly
Was du brauchst
  1. Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Battery: Schritt 1, Bild 1 von 2 Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Battery: Schritt 1, Bild 2 von 2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
  2. Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: Schritt 2, Bild 1 von 2 Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: Schritt 2, Bild 2 von 2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 39
Insgesamt: 2,179
